- Jan 25, 2015
- 2,558
Pulled the argo:
in today to install the front drive chains. I remove the front chains when running tracks to make it easier on the other drive chains. Basically, so they bind up less.
The rh side chain was super slack for some reason and it was tensioned properly when I removed it. A little investigating and:
Ugh.
The outer bearing housing has spit and a chunk has gone awol. That's the inner bearing race you see on the shaft and the balls are just absent.
Adding to my "ugh" is they don't make that part anymore. They only sell an "upgrade" kit that allows you to install the newer bearings they now use on argos.
Guess I have my next project for the Atlas 10F.......lets see now: aluminum or mild steel.......leaning towards steel so it won't blow out like that again. Won't be fancy though. Just a solid piece cut with the right diameters for shaft, bearings and seals as well as fastener holes.
Ugh.
