What collet is this?
CoopVA
Feb 1, 2014
339
There was a face plate that came with my lathe that had this bolted to it...
Inside was this collet...
One side of the face of the collet is stamped 1/2, which I believe is the size. Opposite this is stamped a "T" with something else that looks like it was destroyed when the slits were cut.
Any body know what type collet this is?
ImageUploadedByTapatalk1416778574.426321.jpg ImageUploadedByTapatalk1416778601.708188.jpg ImageUploadedByTapatalk1416778612.963489.jpg
Looks like a B&S #21
There other sizes but it is over 20 years since work with this collets
Dave
Hmm... I'll have to take some measurements.
Yep, could be. Could be a swiss too... Will definatly have to take measurements.
The holder looks to be home made. I like it, and hopefully will be able to determine it's actual type... I wonder if the collet was home made too... The stamping is kind of crude...
It is the same shap as the collets in my die grinder.
So I took some measurements.
I searched through all the collets on ShopHardinge.com and the closest I could come up with is a Swiss Type TF24, which measures .9367x2.440x15*.
I do believe the TF24 will work. I measured the bore, and it is @ .937 +/-. I may get one just to test fit.
So the search continues...
Found a 7/16" TF24 on eBay for $14... We'll see how it fits...
