- Aug 3, 2021
- 15
I've been following along. I didn't make any suggestions because I didn't have any better opinions to offer.
Good to see you sorted it out.
However, now I'm confused. What happened to the 100 tooth gear indicated on the chart?
Did you count the teeth and only found 92 (another chart error?)?
Is 92 a typo? please elucid
Yes typo I meant 96! My apologies, Okay so after a lot of messing about, as you see i took the recommended gear setup, which I doubted until today once I removed the spindle pulley etc I realised that the 3 top gears were irrelevant and the headstock and them gears had a 1:1 ratio, then I realised I was fitting the gears correctly, however as you can see from my previous diagrams with all the drive gear set ups and knob selectors, you can see some of them on the supplied chart were correct but some of them were off. Someone on this thread mentioned that not all the diagrams are accurate and can sometimes be off so I played about with the gear cogs leaving the gear knobs on C-3 to try and find my thread pitch with different gear combinations. So at first with the recommended gear setup I was getting a reading of 1.32mm pitch, I then put the 63 tooth cog on the lead screw took another reading and I can’t remember what it was now but was marginal, I had to slow the chain down and thought changing to the 96t gear would do this To be totally honest it was all abit of luck trial and error a few days of messing around with it…. Possibly even more hair loss! Most of the chart is correct I highlighted green for the ones that were correct, and red for the few that weren’t, the gear combination 30t-96t-70t-63t with all the selector knobs being in the position they should be in seem to fit (highlighted in green) I know there were some discrepancies with other gear combinations, I will have a look at them another time, it’s quite time consuming. I’ve started to make my own chart which I know is precise for future reference. However the recommended gear combination for let’s say a 0.75mm thread pitch, 30/100/54t/72t selector knobs C-3 isn’t correct however I found that the 30/100/70/56 on A-1 is in fact 0.75mm pitch not the stated 0.7… I’ve written my findings on a piece of paper to keep note of them because the diagram written on the lathe is completely wrong in a lot of cases. The chart I’ve made so far is 100% accurate, will be trying different gear combinations in the future and will upload my findings. It’s 5am I hope I’ve made some sense. ThankyouI've been following along. I didn't make any suggestions because I didn't have any better opinions to offer.
Is 92 a typo? please elucidate.
