I've got one of these milling arbors for my mill - it holds things with a 1-1/4" bored hole:
I have nothing to put on it though so I've gone shopping. It seems that the arbors are much cheaper than the attachments.
I can go with one of these:
It looks to me like that is just a fancy expensive fly-cutter but with multiple tips. So it's good for surfacing a flat piece of metal, but not for hogging off big chunks in one pass. I can do that job with my generic fly-cutter for 1/10th the price.
My other option is one of these:
Although they're cheaper than the first option, they're still not cheap. They look to me like it just turns the arbor thing into a big fat end-mill. I've got end-mills out the badonkadonk (did I use that word correctly? It's so hard keeping up with the hip cats' lingo.) so this would just be a bigger end mill. I'm not sure of the advantage in that over a regular end mill except it's costing me more per piece of swarf. I can also get one of these in what is called a hogging cut, which is supposed to take off big chunks quickly I guess and then I'd go through with a regular end-mill to clean it up?
Like I said - I've already got a few generic fly-cutters and when I get the grind just right I can get some nice shiny surfaces. And I've got end-mills in every configuration and shape up to about 1" thick. So do any of the two things above bring any new capabilities to the table? Is there some other use for the arbor I'm missing? If you had to recommend one or the other or both then where would I find the most affordable (Grizzly doesn't seem to have anything that fits on the arbor except the first attachment and it's over $200).?
thanks
Joe
thanks
Joe
