I have a chuck wrench I made for one of my chucks. The handle has three shallow grooves cut in it, one in the middle, and one about 3/4" from each end. The shank or the part with the cross hole in it has a drilled hole down through the cross hole. I installed a spring and a small bearing ball in the hole. I carefully slid the handle through the hole so the ball detente was positioned in the middle groove of the handle. If you need a little more leverage, slide the handle into one of the end grooves. I'll have to find the chuck wrench and take some pictures and post.
