I have a project coming up with a threw hole .750 x 6.00 inches long steel or stainless. I'm looking for a bar that can do this but would like to makeup a set of bars with a standardized insert if possible. Any affordable options suggestions?
What tolerance is on the .750 diameter ? If it was close , I would drill undersize , run a boring bar thru just to true the hole and then ream it . You're approaching a length over diameter issue trying to bore to a tight tolerance . They do make solid carbide bars but they are pricey .
Line bore with a 5/8” bar held between centers. Also here: Line BoringI have a project coming up with a threw hole .750 x 6.00 inches long steel or stainless. I'm looking for a bar that can do this but would like to makeup a set of bars with a standardized insert if possible. Any affordable options suggestions?
A steel boring bar is typically good for 3-4X the diameter of the bar for max depth of cut - unless you don't care about maintaining any kind of tolerance. A carbide bar is typically good for 7-9X diameter for maximum depth of cut. For this job you would need a 5/8" diameter carbide boring bar that is at least 8-inches long, and that will set you back over $500. Here's one example. Your best bet for this job IMO is to drill slightly undersized and use a 3/4" reamer.
