- Dec 27, 2014
- 4,066
I'm gonna take a guess at this.....
Its' for second operation on a production part. The part has a concentric bore which would be a very nice fit on the stub arbor.
The operator installs the stub arbor concentric in the lathe, with the loose pin in place. The operator then slides the work over the arbor and turns on the lathe. The pin wedges itself into the corner between the arbor and the work, spinning the work. The work is completed, the lathe stops and the operator twists the work top toward them, loosening the pin. They remove the work from the lathe, dig the pin out of the chips and repeat the procedure on the next piece.
And Bob's your uncle.
