I would also guess a threading top-slide.
The lever (and rack and pinion) offering a way to quickly retract the cutter for setting up for the next pass.
-brino
Well made and designed to go onto a base to rotate. The feed is on a rack and pinion with end stops. Not sure what attaches to the top with the single nut.
Looks like it can be swiveled on a lathe cross-slide so useful for production turning of short tapers, grooving, trepanning, etc.
Has a Hardinge-esque vibe to it.
