What is this used for?
rickv1957
Dec 14, 2014
3
Hello,
This was in a box that came with the South Bend 10L I bought.
Does anyone know what it used for? It is welded into collet, and
you can't fit allen wrench in the back.
ThinWoodsman
Jul 8, 2018
761
Probably a fixture for repeat work? If it's welded and doesn't unscrew out of the collet, then it was a setup-once-and-useforever sorta thing. Do the metal bars either side of the round hole move? that would make it a clamp.
JimDawson
Global Moderator
Staff member
H-M Lifetime Diamond Member
Feb 8, 2014
9,752
Looks like a special shop made tool for a specific use.
derf
Oct 3, 2015
917
Looks like it could be a driver for the tang on a morse taper tool.
Superburban
H-M Supporter - Gold Member
Jan 2, 2016
1,484
Looks like the inner section fits into the internal threads of the 5C collet. Try unscrewing it from the collet.
rickv1957
Dec 14, 2014
3
Can't adjust anything, diameter is .375, flats are .312 , the set screw in back serves no purpose? It is welded in near the rear threads. Could it be something a gunsmith coud use? Cleaning out and don't want to throw something out that someone can use.
ThinWoodsman
Jul 8, 2018
761
Set screw is probably an artifact of whatever arbor was shoved into that 5C collet. Perhaps it used to be an end-mill holder or was an arbor extension or something.
So, the opening does not adjust, meaning it is for a specific size and shape part (or tooling). Is the hole a through-hole? or is there effectively a depth-stop?
Greybeard
H-M Platinum Supporter
Nov 12, 2019
5
Memory says I think that's a broach holder such as for cutting splines...or for Swiss automatics?
AdBlock Detected
I've Disabled AdBlock
