- Jun 8, 2016
- 603
I have a .375 through bore, about .150 thick. I need to bush the hole and drill new hole of center to the original bore. Through the new hole will be a shaft that will spin. This will see very light load, being turned with fingers.
What size shaft should I turn?
Everything is simple steel, either CRS or HRS equivalent. I can freeze the bushing in home freezer, heat the piece its going into in a standard kitchen oven, or use a 20T hydraulic press. Also any combination.
