Whats These Gears For?!?!?
Keith Foor
Aug 4, 2015
291
OK, so some of you probably read my post that I got an OLD (serial number 23190) South Bend Series O lathe that's change gear. Got lots of gears, that don't fit the thing. The shaft had been sleeved to fit a larger size but is originally 5/8. Common South Bend size for the lead screw and a 20 era 13 inch lathe lead screw. These gears I got are 7/8 ID and .950 wide. Figured out they aint South Bend at all. So what do they go to.... Any idea's? And is anyone looking for some gears this size.
How about some pictures and tooth counts of the odd ball gears?
Quantity Sizes type of gears are they, all kinds of gears can be used to build things . You may come up with a project to build something. If you know someone who needs them sell . If you really don't want them I'm sure someone here will . Even me but I don't need them.
Yep, pics are helpful.
Any numbers cast or stamped into them?
Cast or steel?
Any idea of pitch?
You might not know the answer to that, I only learned about DP a year ago.
However, this might be a good reason to dig in and learn how gears are measured.
Daryl
MN
