[4]
When a Knurling Wheel Seizes Up
[3]
[10] Like what you see?
ddickey
H-M Supporter - Gold Member
Apr 21, 2016
1,884
Likes
934
#1
rgray
Nov 26, 2012
1,062
Likes
558
#2
Now that's interesting.
Always oil the part being knurled and the wheel. doing it in the same swipe with a brush makes it simple.
I'm sure there are better lubes for the wheel than cutting oil, but I've been getting away with it so far.
dulltool17
May 9, 2014
336
Likes
217
#3
OIL, OIL, OIL.
Salvage the part by cutting a legit groove where thee tool seized. Sometimes success is just a well-disguised screw-up.
ddickey
Apr 21, 2016
1,884
Likes
934
#4
That's a good idea. That part was dripping oil so I don't think it was a lack of that.
Fitter Bill
H-M Platinum Supporter ($50)
Jun 17, 2012
50
Likes
26
#5
Mine has done the same thing. I removed the knurling wheels, cleaned and lubed the shaft and the hole in the knurling wheel, there was fine metal pieces inside. No problems now. I have carbide shafts in mine. They take a pretty good beating.
benmychree
John York
Jun 7, 2013
2,754
Likes
1,992
#6
I use hard dowel pins in my knurling tools, never a problem; they are about as hard as hard gets, of course carbide not considered, sounds like a good idea.
projectnut
Brass
Apr 14, 2014
522
Likes
355
#7
OIL, OIL, OIL.
One of the machinists I used to work with always said, "it isn't a mistake if you can repair it before the boss sees it". That was right after he bored a 2" hole .250" out of position. No problem, he just turned a 2" plug, pressed it in the hole, and had the welder weld it in place from both sides. He milled the part back to the original thickness and rebored the hole in the proper place. You couldn't tell there had ever been a misplaced hole.
It was a lot of work, but it was a large, expensive part, and would have taken days to replicate.
rgray
Nov 26, 2012
1,062
Likes
558
#9
That reminds me that I did wear a groove in some knurl shafts that I made out of 0-1 steel that I hardened.
I replaced them with HSS.
Can buy sticks of it in round and cut the length needed with a grinder.
Haven't hurt any of those yet, if I do I will try the carbide.
[6]
[5] [7]
