• WTH HAPPENED TO H-M?
    After accidentally deleting a folder, we asked our web host for a backup. As nearly as we can figure, the 1/23 backup did not contain any attachments (over 250000 or avatars for our members). We then asked them for a backup to January 1, 2020, and THAT backup had no attachments or avatars, etc. Their backups were incomplete apparently, and overwrote our files with empty attachment files. We are very sorry for this. We are doing everything and anything we can to right this. HM
When parting on the lathe, avoid letting the parts fall.
shooter123456
Jan 20, 2016
501
I was parting a piece of 3" aluminum round on the lathe. The chuck was spinning around 150 RPM and I turned the machine off as soon as it finished parting. I just let the part fall, thinking it would plop down like every other thing I have parted on the lathe. Unfortunately, the piece was too wide to fall down through the bed, instead it fell on one of the ways, caught a rotating jaw, and got jammed between the chuck jaw and the carriage. Luckily nothing was damaged but the chuck being forced to stop by the shiny new part you just finished isn't pleasant and could easily have broken something.
Here are some pictures of roughly what happened. I didn't think to take pictures right after, but this is a dramatic re-enactment hoping it will stop someone from repeating it in the future.
If you stick a drill bit in the chuck backwards and slide it in the hole (if you are parting something with a hole) it can catch it just fine.
BtoVin83
Aug 30, 2017
254
My brother was parting some 36" transite pipe and we used the crane to catch the part. That was fun
H
Hukshawn
Forum Guest
Register Today
Good try on the re-enactment. Next time try the csi method. Use a bit more blur and grain in your photos, crank up the saturation. Maybe tell the story from the jammed parts perspective, and some expensive camera cinematography angles.
Ray C
Nov 16, 2012
5,586
LOL: And don't forget to interject commercial advertisements every 60 seconds followed replaying the last 40 seconds of the production when the commercial ends.
To the OP: Glad you posted this. It's a good thing to watch for.
Ray
RJSakowski
H-M Supporter - Gold Member
Feb 1, 2015
4,612
A good lesson to learn. I usually use a pin or drill bit in the tailstock chuck to catch small parts so I didn't have to fish them out of the chip pan. I never really thought about rogue large parts doing their worst.
wlburton
H-M Platinum Supporter
Jan 8, 2013
167
I made a hand crank for my South Bend lathe for inside threading (it has a screw-on chuck so I'd rather not run it in reverse) and have used it for the last little bit of a "scary" parting-off (large diameter steel part had to be supported by the tail stock so the part was trapped between the stock and the live center) and it parted-off just fine under hand power. Whatever works!
