- Sep 23, 2015
- 170
I picked up a set of cast iron rollers from a very old Cane Mill today. Originally I suspect they were greased with something and the shafts turned in the "bearings" easy enough. They don't turn fast or for very long when you are juicing sugarcane to make syrup. I'm thinking of making some plastic "bearings" to install between the shafts and caps to eliminate the need for grease. The shafts are 3 1/2" diameter, so if its a tube it would be a big one unless there is sheet soft enough to form to the radius of the caps.....Ideas? Advice?
