Well, I can't say it is good for the reamer, because it obviously destroys some of the back relief, but I mentioned it as a desperate measure to get a reamer to cut smaller. In the case of a brand new reamer, sometimes a less than perfect grind can leave microscopic burrs on the edges, and a light hone can remove them and help get it on size. When I said stone it by spinning it in reverse, I meant very lightly, and not for long. It doesn't take much to reduce the size a few microns and lessen the tendency to over-cut. Also, sharp(new) reamers can tend to take a bit of twist, especially spiral reamers, and especially if too much material is left in the drilled hole. This "unwinding" can make them swell, so to speak, and cut larger than they measure. Drills and taps do the same thing, but is not usually as critical and is seldom noticed, or a problem.
On another tip, don't expect the reamer to cut dead on in a drilled hole in general, especially in the first few holes, or dead on location. Best to single point with a boring head, leave a consistent amount of material for each hole to be reamed. Generously apply cutting fluid.
I have fought with reamers on a 0.0003 total tolerance hole in Ampco 45 for hundreds of parts......learned a lot. Lots of press fits for dowels in die sets....I generally love reamers, for what they are good at.
