Hi Brian,
Yep that spec sheet is mine down to a T. Mine is branded Herless but as far as I know thats just an aussie firm that imported asian machinery and put their own name on them.
I havent found the low end speed to be a problem yet but that may just relate to my selected work. I make stuff for myself and mates and the odd paying job, in plastic, ally, bronze/brass, steel & cast iron.
Mine has metric dials, and the quill is MT3. Best thing I ever did was fit DRO's to it The 1 shot oiler works ok but I had to make a new pump for mine, (the old cast housing broke). Mine had a tough upbringing before I got hold of it, and the fine quill feed has a couple of sticky spots on the worm wheel. I have done a bit of work to smooth it out, but its still not the best. The table movement is good and smooth, (they have adjustable gibs) as does the knee. They use a split cast iron nut on the x axis for backlash adjustment, and mine is cracked. I am going to make an acetal replacement one day. You can easilly see the nut from underneath with the help of a torch. Cant help with $ value. I paid $500 for mine about 10 years ago, but that was at a big clearing sale with only 1 other (phone) bidder. I got at least another $1k worth of tooling with it. Just right spot right time. For home use I would recommend it, what sort of work do you have in mind for it? Are you mechanically minded, I am happy to go into more detail on fault finding/checking if you want?
Cheers Phil
