- Oct 31, 2015
- 469
I bought a nice welding bench in an auction this weekend that had a large Wilton vise on it - I think it's a C3. While I was mainly interested in the bench, I was excited to have the vise as well. On closer inspection, I found that someone had attempted to weld the stem to the moveable jaw. As you can see from the pic, the weld has completely failed. Also, there are 3 tapped holes in the jaw casting for bolts to jam onto the stem. After removing the bolts, I was able to slip the stem out of the casting. There is absolutely no thread engagement between the stem and casting. So I'm puzzled as to how this happened in the first place. Was the fit sloppy from the factory and eventually the threads stripped? I don't think properly fitting threads would have stripped like that.
Regardless of why this happened originally, I'm left to decide if this vise is worth re-repairing, and if so, how to go about it. Some options I've come up with so far are:
- Use the tapped holes in the casting and drill into the stem, so that the bolts actually pass thru the wall of the stem.
- Grind the failed weldment off of the stem and braze it in the same place. Possibly do this in combination with option 1.
- Make a new stem with threads to match the casting. This is obviously the most complicated (and quite possibly beyond my ability)
