- Apr 26, 2022
- 3
Hello there, I am quite happy I found this community as I have a few future projects I could use a little help with.
My current project is fixing a AC motor to a new switch for a paper shredder. The current switch seems to have failed in one direction, but works when in the forward direction.
This is the stock wiring switch, with what seems to be an interrupt
I have a small DPDT switch of the same size to attempt repair, model Selecta SS118-BG
The motor in question seems to be a Westinghouse 317P
There are 4 wires coming out of the motor
I do hope someone would be kind enough to help me replace the original switch with the new working one. If this switch is not compatible or I need to remove the interrupt and add an external drum switch do let me know which switch you would recommend to get this shredder back to 100 functional.
