work rest for KMG belt grinder?
A
Alan H.
Forum Guest
Register Today
I have a KMG 2 x 72 belt grinder. I bought my base grinder from Beaumont Tool Works and then fabricated the stand and put together the drive. This is one of my favorite machines in my shop and it gets used almost daily for something when I am in the shop. I grind my own HSS lathe bits for special tasks and use the belt grinder for some steps of that.
I am now on the hunt for a work rest design to either buy or make. I am imagining a T-slotted rest that could accommodate a small miter gauge when desired. Also hoping for one that is easily adjusted for different angles relative to the platen.
I have seen the D-D Work Rests that are prevalent on ebay and they look good. I do not think they offer the T-slot that I am after. I recently ground a HSS bit to make some hose barbs and I needed a fairly precise angle on the nose, so a T-slot gauge would have been helpful.
Any ideas or examples would be appreciated.
Bob Korves
H-M Platinum Supporter
Jul 2, 2014
7,338
See the one that Mikey made. I have no idea where to find it, but I think he will be along pretty soon to reply to your post...
mikey
Global Moderator
Staff member
H-M Lifetime Diamond Member
Dec 20, 2012
7,378
Alan is aware of my design, Bob.Thanks for remembering.
Alan, I should think that making a T-slotted table would be simple. Rabbet an edge on two pieces of steel and plug weld them to a third piece that will form the bottom. Then make a miter gauge and you should be set.
mikey
Global Moderator
Staff member
Dec 20, 2012
7,378
Hey Alan, I was thinking about this during dinner and wondered if a T-slot arrangement is a good idea for a belt grinder table. The grit and metal dust will accumulate in the slot and may interfere with smooth operation. My table slot is just a slot and the protractor I use never gets sticky.
Anyway, food for thought.
A
Alan H.
Forum Guest
Register Today
Thanks Mike, you are absolutely right. An actual T-Slot would be a bad idea. I really meant a slot for a miter gauge. To get a T-slot the thickness of the work rest plate would need to be too thick anyway. So yes, a slot is what I was thinking about and all I am after.
In addition the miter gauge needs to be low profile and small. I did a bit of searching to see if there's one commercially available with no luck yet. That is likely something one would need to make.
I sent the gent who makes D-D Work Rests a note to see if he made slotted work rests and he does not. He is willing to make a "one off" but of course I have all the equipment to make one myself. An option is to buy his work rest system and be done with it. Since he makes them in some volume his pricing seems reasonable. For those unfamiliar with his work, here's an ebay link to one of his several offerings.
So on with "the studies".
Bob Korves
Jul 2, 2014
7,338
Alan, I made this miter gauge for my carbide grinder, was missing when I bought the grinder. Nothing fancy, made with remnants found in the shop, but it does the job well. The table slot is only .131" deep and I made the guide from 1/8" thick material. That sounds shallow but is actually plenty of depth for the slot.
A
Alan H.
Forum Guest
Register Today
Thanks Bob,
Looks good - is that a protractor that you put on there?
I think that depth is quite adequate for this service and easy to brush out/clean.
Bob Korves
Jul 2, 2014
7,338
I can't find where I printed it from on the web. Here is a page to get you started:
https://www.bing.com/images/search?q=360+Degree+Wheel+Printable&FORM=HDRSC2
The one that is on the protractor is ink jet printed on white photo paper and then clear coated. I also have one printed in black on transparent material that I will use over a white background if and when this one fails.
mikey
Global Moderator
Staff member
Dec 20, 2012
7,378
Alan, I suspect you will find that a protractor on a grinder table will have limited utility. Not saying you don't need it; just that you won't use it often. In fact, if your table edge is square to the platen I would say you don't need a slot at all; just two straight arms (one of which will reference off the table edge) joined with a locking screw will be sufficient and will likely be more accurate since it eliminates the play that exists in a table slot.
About the only time I used my protractor was when I needed to grind threading tools and the play in the slot made this process not that accurate. Nowadays, I scribe my grinding line on the tool and grind by eye. It's more accurate for me to do it this way and I almost always nail the angle the first time.
Not being a naysayer. Just wanted to offer the perspective of a long-time belt sander user.
A
Alan H.
Forum Guest
Register Today
Mike,
You may well be right and a metal protractor is cheap enough and works as a guide.
However grinding a HSS lathe tool recently made me believe it would have been nice to have a good miter gauge guide.
Here's a photo of an 8 mm - 1 threaded 3/16" hose barb adapter I made and a HSS tool I ground to cut the barbs. The nose of the HSS tool is at 7 1/2 degrees and it's 3/16" wide. The second photo shows this adapter in place for the discharge of a Trico single shot lubrication pump I am working on. I ground the HSS tool to shape on the KMG and then finished the cutting face on an 8" CBN wheel.
When grinding the tool on the KMG I thought it would be easier to achieve the 7 1/2 degree bevel on the nose with a good guide vs. the metal protractor I used on the edge of my work rest. Obviously the pursuit of a perfect 7 1/2 degree angle on the grind is likely not necessary but that is what I wanted to replicate the barbs on some other hose barb fittings I acquired from McMaster.
I must admit that the edge of the KMG supplied work rest is not machined well enough to act as a great bearing surface for a guide. Perhaps the metal protractor would be fine on a higher quality rest and it may well work as well as a slotted miter gauge which started this thread.
Thanks to you and Bob for the input to "the studies", much appreciated.
mikey
Global Moderator
Staff member
Dec 20, 2012
7,378
+1 - good job on the bit and piece, Alan.
If I have a fussy angle like that, I use a Sharpie to blacken the tool bit and scratch a line with my Starrett protractor. Then I just grind it by hand and check it after grinding to make sure I hit my angle. In the beginning, a protractor can come in handy but I think you'll find that its easier to push the bit into the grinding medium without it.
Don't let me discourage you from making a slotted table or using a protractor, Alan. If that is what you need, then you need it.
sanddan
Jan 22, 2012
655
mikey, could you please share your design? I'm thinking of building a 2x72 grinder and haven't seen it.
A
Alan H.
Forum Guest
Register Today
A
Alan H.
Forum Guest
Register Today
I decided to order a D-D tool rest and go from there. I have a few metal protractors and may well stick to using them after I get the rest. I believe the work rest table is ground so it should be quite good for that.
Here's an Instagram link of Dan's shop and process of building these. EDIT: Don, not Dan!
AdBlock Detected
I've Disabled AdBlock
