- Jul 20, 2016
- 45
Yes your right on about the old time machinists they could take a chisel,file and scrapper and make their own lathes they were the real machinists true artists I wish I could have seen them make them.When I was first learning machinist work we had some worn lathes and I complained to the machinist leader about it. He said something to me I've always remembered: "Any machinist can run a new lathe, but it takes a good machinist to run a worn lathe."
You will learn SO MUCH more on a worn machine than one that is spot on. You'll learn how to better sneak up on dimensions, filing and polishing to size when needed... tweaking the leveling and/or adjusting the tail stock to get things running better where and when you need it most. The list goes on and on. Just think about the days of old with it's carbon steel tool bits, line shafts, files and fitting and such. Men did some of the most accurate and beautiful work ever done then. Truly an art.
Stick with that machine and learn away!
Ted
