DC motors dont use capacitor startIs the KB electronics controller this one? I'll have to check if this motor has a capacitor start and run, since this one can't be used with those features.
The 3 controllers you listed only the first one will work(most expensive) if it is rated for the full amperage of the motor you have
You will have to know the HP rating of the motor to get the right plug in resistor
The second one on the list is only rated for 2 amps
The last one you listed was rated at 6 amps but they are for fans etc low torque applications
I run a simular controller on my mill drill with a 2 hp dc baldor motor and it is fused with 10 amp fuses(240vdc)
Make sure the controller you get will handle the current draw of your motor
