- Apr 30, 2012
- 2,401
Ok so the fan will rotate in the correct direction no matter what wire you choose?
yes it should
Its the demo processor 2.4GHZ Intel Pentium 4is your mach3 the demo or did you purchase it?
and what processor does your pc have?
so how are you doing so far any pics to post?
inside the case the wires to each plug will also have a shield wire. (bare wire) these get grounded to the case near the plugs. you can connect the shield wires all together then add a piece of wire to reach a ground screwed to the metal case.
steve
Ok so the wires from the plugs go only to the controllers correct? and only leave the shielded wire on the plug side and cut the shielded wire back on the controller side? Does it matter which controller I use for what plug or do we pick that when hooking up the breakout board? Thanks. I will post pick today.
yes wire the controllers to the plugs the way you said what ever order looks the best is fine and yes you can connect the controllers to the breakout board in any order because the motor are not on the machine yet and if you wired all the plugs the same we can determine axis at the plugs.
did the breakout board ever get there?
steve
