- May 27, 2016
- 3,471
.. and broken .. and you now have a tangle!
It does not matter what kind of reel, cotton, fishing line, guy rope, they all mangle up in a similar way.
In my case, a new full reel of 1mm2 insulated copper wire, a gift of industrial surplus that does have future use for me.
The reel is (approx in inches) about 10" diameter, with middle metal section 4" diameter, and 4" between the side cheeks.
It drops, and POW - one of the cardboard side cheeks comes away from the rolled tin metal middle. Hundreds of loops of wire go spilling across the garage, forming special sorts of tangle knots as the larger outer loops leave the smaller loops behind. That size reel is bigger and heavier than the usual 100m. I just don't know how much was on there. Oh dash and darn it! (+ further expressions of a more robust nature)!
Given the mess, and the time and effort to get it back, it might have been better to just put the whole lot in the trash, but I was unable to summon up enough environmental indifference! I scooped what loops were still a bit together onto a piece of broomstick, and stood it across a pair of axle stands at max height. Then, using a similar reel donated from another reel that was about empty, I found an end, and started undoing the Father and Mother of a tangle. Passing the (getting heavy) reel under and over the broomstick, and between spools of wire on the floor is becoming an upper body workout! I see it there. It offends the eye. At the times I can, I recover some more onto the "new" reel. Oh yes - it has to go on the new reel "kinda tidy", though not altogether perfect at the sides.
Is the need to get all that wire back onto a reel some kind of "waste not, want not" OCD that does not yet have a name, and I am the only one who has it?
