Well crap on a cracker.
tried to install the cam gears and no go. I was just trying to put them in place, not torque them down.
Seems the chain (as it sits) is too short. It seems to be one or two teeth short.
I’m pretty sure I know whats happened.
I think the lower crank gear has allowed two teeth to come out of mesh and now the chain guides won’t allow me to pull the chain around because the crank gear is now torqued and the crank is still locked by the locating dowel.
Were this a “normal” engine, I’d just back off the crank bolt and fix the chain. But of course, this thing is TTY, which means backing it off ruins the bolt.
Tried removing the chain guide pivots to see if I could get enough slack to pull the chain around but no joy.
So tomorrow, I’ll pull the crank locking dowel out and try turning the crank a small amount to see If I can walk the chain around enough to free it up. If it works, I’ll just move the crank back and insert the locking dowel again.
Hopefully it works, or I’ll have to order a new TTY crank bolt. Not a big deal cost wise, but it will mean weeks of waiting….
In hindsight, what I should have done was insert the timing chain “cassette”, then hung the can gears to position the chain properly, then inserted the crank adapter and crank bolt. Then once all in place, tighten the TTY crank an cam gear bolts. None of the manuals say to do it this way, but it would guarantee you wouldn’t have the issue of the chain going slack and dropping a tooth while installing it, thus ending up where I am now..
I’m going to calk the mini desler in town in the am and see if they have any crank bokts in stock, just in case. Wife is going in to town tomorrow, so she can bring one or two hone when she comes. Assuming they have any on the shelf that is…
