- Jan 25, 2015
- 2,558
The engine is in time. The crank is locked by the dowel and the cams are locked by the cam tools.I've been there, you need to put the engine in timing then torqe the bolt. I had it be half a tooth off, many ford engines are like that, horrible design. You may as well remove that bolt, install the cam sprockets torque them, set the timing tighten the bolt by hand then unlock the crank and cams rotate it two circles by hand and check the timing marks, if right torqe the bolt and re check.
There are no timing marks on this engine. The timing is set by locking the crank in its timing position, then locking the cams in their timing positions, then install the timing chain and gears and then TTY them all in place. The location of the actual crank and cam gears is irrelevant because the timing is set by the locking tools. Rotate whichever gear to whatever radial you want, it just doesn’t matter.
This was most likley my own fault and not holding the cam chain fully up when assembling the timing set, which likely allowed it to "loop" off a crank gear tooth at the bottom of the run and now, here I am.
