Getting there:
Thats an aftermarket aluminum rocker (cam?) cover. The oem ones are plastic and prone to cracking and leaking over time in the hot engine bay. The oem one also has the pcv built into it and the only way to change it is to install a new rocker cover. More franco/german engineering…I mean really, who designs a non-servicable pcv system?
I suppose it might make sense sitting in a cubicle staring at a cad diagram, when your only concern is a design that lasts the warranty period without costing the oem repair charges. But after a couple years when blowby starts to get a little more “energetic”, you’re going to need to service that valve. With the oem, your only choice is a new rocker cover for hundreds of dollars. Gawd help you if you hang on to the little bugger for 10-20 years and have to go looking for that rocker cover if your’s has cracked…
You actually
CAN change the diaphram on the oem covers, but it’s not with oem parts. BMW‘s intent was to replace the whole cover if the pcv diaphragm splits or otherwise fails. The aftermarket way involves an aftermarket diaphragm and fooling apart some one-way clips that you can’t even see, let alone get to. What usually happens is you break the clips or crack the valve cover, which means you’re spending around 200 bucks to replace it.
The aftermarket (cast aluminum) cover for an N12 I’ve only seen for sale rarely. The aluminum (Turbo) N18 covers seem to be everywhere, but not the N12. I ran across someone selling a couple on ebay and grabbed it. Wasn’t cheap, but worth it to ditch that stupid plastic one. They’re hard to come by and I wasn’t going to miss the opportunity to put this potential weak link behind me.
As an added bonus, the pcv diaphragm is replaceable on this one by simply removing three screws. Thats an important point for me because when the pcv diaphram ruptures, tears, clogs or otherwise fails on these engines, they just start sucking oil out of the rocker area and you get those big blue clouds and fouled spark plugs.
Aftermarket cover makes all these potential issues go away.
I like that!
I also re-locked the crank and cams and changed out the crank TTY bolt. I wasn’t confident in my 180 turn on the previous bolt because my angle gauge stalled in a few spots as I was turning. I believe the ring on the gauge got stuck up against the chassis and the result is an inaccurate reading. So I installed the new bolt the wife oicked up and made sure I got a “clean” 180 turn on it. Sure, I wasted a TTY bolt, but if the timing had slipped or (worse) the bolt snapped off while the missus was driving it, it would trash the entire engine. Having a new bolt on the shelf wouldn’t do me any good at that point, so it only made sense to change it out. I did the witness mark trick to make sure it went 180. Make a paint dot on the bolt head and another next to it on the housing. Crank the bolt down, take the angle gauge off and the dots should be 180 out….
