You have not mentioned any tolerance either specified by the customer or for yourself if a hobby part.OK. If so, how do I "work around it"?
I did read the entire post and was merely pointing out that chasing tenth's on such a machine will be maddening at best.Wreck if you read his original post he clearly says the parts are usable lol
Been hangin out with FOMOGO or what bra? Haha
But true to what he says, working within a thou is actually quite good considering the non precision machine you own, I think the atlas lathes are good hobby machines, mine has served me ok, it lacks but it does most of the jobs I need it too. BTW I have half inch ways, Mic each ways width, I'm not sure what they are but I think they are around inch and a half maybe? But that wear could be causing the taper, not the thickness of 3 8ths
... BTW I have half inch ways, Mic each ways width, I'm not sure what they are but I think they are around inch and a half maybe? But that wear could be causing the taper, not the thickness of 3 8ths
...I even measured the width of the ways. Consistent 1.499 measurement for both front and rear bed way...
