- Mar 19, 2014
- 2,681
I frequently travel the Flea Markets. And find lots of Rigid cutting fluid. It works for me. I have maybe noticed that the older formula stuff can stain bare metal? So if it that concerns you?
I forgot he did mention bacon grease.. but in my mind that would get rancid w/o refrigeration ... NO?
Are there any concerns about residual salt in bacon grease? I have noticed that lard is still available in supermarkets though.
If the detergent in oil would corrode the mill, why is it used in automotive engines? I would think it would corrode the exposed metal parts like the crankshaft, the lifters, etc. I had been lad to believe that the reason for not using oil containing detergent was that it kept particulate iun suspension so the car's filter could remove them but in a machine without a filter it prevented them from settling out, increasing wear.The other night I had a conversation with a friend. He's a gunsmith, his dad was a machinist. We were talking about my mill.
He said I should not use SAE 20 for the 8520, that I should use non-detergent 30 wt oil, that detergent will corrode the mill. This I believe to be true, but just checking is he correct.
Honestly if you want to use motor oil as cutting oil, a 2 gallon jug of SAE20 (roughly equivalent
to ISO68) non-detergent motor oil goes for around $20 at TractorSupply. Not as cheap as used
motor oil, but you can use this to lubricate your mill or lathe as well. For my lathe and mill gear
boxes I will still use Mobil DTE Heavy/Medium (ISO68), but I have used the SAE20 to flush out
my lathe gear box once. The oil from the factory got really black after break in and I didn't want
to waste the more expensive Mobil oil only to get that fouled up too. I used the SAE20 for a few
weeks, then drained it, and then refilled with the Mobil.
To me the new clean oil is nicer to work with and makes less of a mess. If I wanted to quench after
hardening, or to oil blacken a part, used motor oil would probably be the way to go, but as a
cutting oil, I'm sure it would work, I'm just not a fan.
