found an enco 13"x40" lathe
Ok, switch in question is an hz5b 10/2 d009 this is s high power switch used to control the forward and treverse of the carriage. It has8 terminals, 4 witch positions. I can't dl PDF files with this phone, so I'll get it tomorrow. On wifi.
I am putting this here in case someone with an older grizzly encourage or other Chinese brand 4003 or encourage 13x40 lathe has a carriage select problem... this is likely the piece. I found the grizzly. And encourage numbers I'll post them tomorrow
Rich
For those reading- Rich's phone is changing "Enco" to "encourage". Took me a minute :)
Bernie
Rich
What happened to the switch? Just unplugged? Or damaged?
Otherwise looking great man!
Bernie
Wow! You did an amazing finishing job, Rich! Looking forward to seeing it run! :goodjob2:
Bernie, I was wondering about the switch, too, as well as Enco/encourage... :shocked:
My phone spell checks enco to encourage if I do not correct it.
My switch should be good, no telling yet, still working my way thru the electric. When I did a search for the part and the pinouts I ran into a thread which had several users of grizzly and enco lathes that had bad switches and were looking for cross reference parts.... figured would be nice to put them here also
Always nice to leave a path for those behind to follow.
Rich
Cudos to grizzly for making such a well thought out and informative manual for their 4002/4003 series machines. Lots of great information on the operation of the machine as well as detailed wiring diagrams, the wire colors are different but the switch pinouts and the terminals are the same so it is just a simple matter of hooking up what goes to the propernterminal! Thanks grizzly!:man:
rich
she is alive!
I found a metal " middle gear" as it is referred to in the grizzly manual. As a temp solution I'll use this one, it will also serve as a pattern to make some plastic gears.
I need to pick up 6 quarts of iso 68 gear oil and some way oil, than hopefully fine tune and then make some chips :)) the fun part is almost ready to begin.
rich
When I started reading this thread I had no love for Rich. Thinking anyone who scored a free lathe was just to lucky for anyone to like. Then, as I read along I discovered Rich and people like him (and me I like to think) are an endangered species. Self reliant humans. By the time I reached this point in the thread I was impressed enough to shoot him a "like" and make this post. Hope you get the job. Bib
Any update. Lathe still working for you? I have the same lathe I bought new in 2004.
