- Apr 12, 2012
- 579
Belts are usually considered suboptimal for sharpening HSS lathe cutting tools. Great for roughing but not so great for finishing. If you look at a tool finished on a belt there is almost certainly a slight rundown edge where the belt piles up in front of the tool leaving it looking almost as if it was used on cast iron and not adequately resharpened. Even if you use the wheel you get a hollow grind with an eroded edge. Granted better sanders do a better job so it is possible that some do a perfect job.
Many people do find that roughing on a belt sander is easier to keep everything square and then finishing on the grinder is easier with the shape already made.
Not trying to say it's wrong. You having knife making equipment puts you on the high end of belt sanders. I just wanted to mention my opinion so that perhaps someone struggling to grind tools won't think their 4x36 belt is the silver bullet and still be disappointed in their ability. Easy test is a good hone then magnification.
Steve
Steve
