The bending brake is starting to be a lot of fun to build now that it is starting to look like something.
I drilled and tapped the holes to mount the thickness adjuster brackets on the base ends. I also machined the micro adjusters that mount on the clamp ends. The following photos show the parts and how they fit on the base ends. The bolt will be replaced with a knob for adjusting.
I want to take a moment here to explain how I locate holes in parts. I am not blessed with a big mill and DRO systems to accurately locate holes, so I do it “ old school”. A good example is drilling and tapping the holes for the micro adjusters. I laid out the first hole with layout dye and a scribe. It is drilled and tapped and the part bolted in place as shown in the photo.
Since this is a ¼” hole, I use a ¼” bit to go in the hole and “sot drill the start of the hole for tapping. Next, loosen the part and move it out of the way. Use a tap drill and drill the hole. It will be perfectly located. I do this anytime I need perfectly matched hole locations.
Now , on to more building. This completes the base unit for the bending brake. The next photo shows the completed assembly.
The hinges are to have bronze bushings in them. I found a scrap piece of bearing bronze big enough to make them. I put it in the lathe and turned the OD .0005 larger than the bore for a “light” press fit into the hinge. The ID is a slip fit for a .625” dowel pin. After turning , I simply parted off two .510” long bushings as shown in the next two photos.
To begin the clamping assembly. I cut two pieces of .500 thick steel plate to size and also sawed a 45 degree angle on the ends. The edges were then squared and cut to size on the mill. The next step I s some holes. There is a .625” hole and a .500” hole that has to be identical in both plates so I clamped the plates on my drill press. Again, not being blessed with a large vertical mill ( I could go and use a friend’s mill, but I want to show another way for those who don’t have access to big fancy equipment.)
I laid out the two holes on one plate, center punched the locations, and clamped the two together on my drill press table. I put a pointed stylus in the drill press and lined up the center punch mark, keeping the edges of the plates aligned also, and then tighten the clamp. I drill a .250” pilot hole . The next drills and reamer are longer, So I put the end of the .250 drill bit in the hole I just drilled and lower the table and the drill with it. Then tighten the table clamp. This keeps my part aligned with the chuck and lets me get the clearance needed for the next longer drills. The hole is then drilled larger in steps and finally reamed to size with a .625” reamer. Next I move to the location of the .500” hole ad repeat the process. I stuck the .625 reamer in the hole to keep the plates aligned while drilling the second hole, as shown in the next photo.
The next photo is the plates two plates stacked with matching holes. I slipped a piece of drill rod in each of the holes to keep the parts aligned while drilling several bolt holes which have been laid out on the top plate and center punched.
After drilling the eight holes with a tap drill , I end up with identical plates. A right and a left. These holes are frilled to be tapped ¼-20, but that will be done later, as these holes first will be transferred to the corresponding parts.
After machining the step pins the plates are installed to check the fit.
