Noga Question
After reading about how great Noga indicator holders are I decided to get one . Is there a trick to the fine adjustment , didn't come with any directions, screwing the knob in or out dosn't change anything on the indicator clamp holder, there is a red button that dosn't do anything eather. Did I get a defective one ?.
Took the knob out , there is what looks like a ball bearing down there , I can manually pull the end down but the knob dosn't do it.
Any advice ?.
Thanks
That knob above the red dot needs to be screwed in far enough to engage the lever. I suspect you haven't got it in far enough!
Knob ran out of threats and it was sh#%t new one is all good.
;) Threats? or Threads? And sorry, I saw other posts and then your solution later. Yep, sounds like a quality control problem! I sure do like mine better than the cheap import ones I have that are so shaky they certainly can't handle a .0001 dial test indicator.
