- Mar 10, 2015
- 309
not sure i see what you saw .. can ya explain ?Large spindle taper is a 4.5 MT is I'm correct, proprietary to South Bend. Look on eBay.
On your machine it looks like someone tried to pry up one of the bearing caps without removing the expamder screws, especially on the rear bearing. make sure your expanders aren't pulling through the sleeve when tightening them.
If you pull the spindle, flush the oil pots/reserviors and either clean the existing wicks or get new ones. Make sure the springs aren't broken and the wicks are not only wicking oil but is contacting the spindle itself. Since the expanders stick with the spindle on removal, you have to line the hole in the bottom of the sleeves with the wick when putting the spindle back. There is a trick to doing that but I forget it at the moment.
Now i did not plan on anytime soon pulling spindle everything is running nice and smooth from what i read saw and tested no need to add take away and shims for the spindle bearings. Note after i readjusted them correctly there is zero runout .
What id like to ask follow up to something you mentioned bout the wicks and filler cups how can i make sure the spindle bearings are getting properly lubricated ? thanks
