- Mar 10, 2015
- 309
I have a 1963 SB heavy 10 tool room lathe. It has everything for it less the taper attachment . Now I may have available a taper attach that come off a 13" Southbend and was looking to mybe retrofit for my lathe . I took a look at it and the only downfall is its bigger.
Do ya think it will be too big or wont matter ? the way height for clamp are a bit larger but don't se why I cant modiphy to accommodate. Now I know the bolt holes for mounting will be spaced wider but dont see why i cant modipy that either. I can pick it up cheap .
First do you think I will fit the machine well w/ retrofit ( lager size) Or not worth the troubles? Thanks in advance
