I am attempting to make a adapter plate for my lathe.
I have a smithy 1220
The spindle and flange are one piece and had 3 mounting holes with just enough access to install the bolts. Removing the spindle would be a choir.
Im no machinist and am a little stumped on a accurate way to get the holes in the correct locations on the adapter plate.
I was planning on machining the adapter to fit the flange on the spindle then removing the 3 jaw chuck and replacing the mounting bolts with hardened tipped set screws then using a draw bar to hold the adapter in place use the set screws to make the locations.
Im trying to make adapter for this 5” 4 way
