Yes I saw that also but dammed if I can find it nowThis was just done in a recent issue of Machinist Workshop or Home Shop Machinist. Author of the article was doing it on some Triumph 650cc rocker arm shafts. It looked great and now I want to have that done on my Triumph shafts. Let me know if you do it. I'd be interested in someone doing it for me. The article was called " A temporary 4th axis on the mill" I was literally with in the past 2 issues of one of those publications. I'll do some digging around to see if I can still find it.
the OLDE TYME way w/ out gearing & sprockets was done BETWEEN CEnters., no dividing head used ...just 2 centers .....w/ a dog attached . to the shaft ......an inclined plane was mounted on the mill base...... the dog rode up the inclined plane as the table moved & rotated the shaft between centers ,while the spindle cut the helix.....calculate the length & rise of the inclined plane vs the rotation desired.
this was long near forgotten technique used on metal planers for slow helices...
best wishes
doc
Find a copy of Brown & Sharpe's a Practical Treatise on milling and milling machines" Tables are shown for different spiral leads and pictures of actual set ups; many other practical items of info. and tables as well.The pic you posted appears to be a rotary table. The way I understand it is a "universal dividing head" has a shaft or some sort that comes out of the backside of the dividing head. This in turn will allow you to connect the unit to the x axis leadscrew to drive the head when the table is trammed. I'm sure the complex part is calculating the rotation ratio and dividing the circumference of the round stock to obtain the desired flute.
That article in Machinist Workshop was mine. Here is a link to my web page that the article was based on:
http://bullfire.net/4th_Axis/4th_Axis.html
The technique might work for what you want.
Ed
