- Dec 26, 2016
- 2,029
You still need a circle cutter but this is how the center bit is modified:
No.For a 100mm hole, using a circle cutter, does it matter about the drill? We're throwing away the center, so a minor crack shouldn't matter? I can see doing the mod for drilling holes in acrylic, but is it necessary for a circle cutter hole?
That's what I thought. Why alter a drill bit if you don't need to. The altering isn't hard, but you have to label the bit and segregate it from your normal bits.
most likely not , I have only one shop made hole cutter with a modified bit so I don't know for sure .For a 100mm hole, using a circle cutter, does it matter about the drill? We're throwing away the center, so a minor crack shouldn't matter? I can see doing the mod for drilling holes in acrylic, but is it necessary for a circle cutter hole?
Why yes, for 2 reasons.For a 100mm hole, using a circle cutter, does it matter about the drill? We're throwing away the center, so a minor crack shouldn't matter? I can see doing the mod for drilling holes in acrylic, but is it necessary for a circle cutter hole?
Protip: Get a standard drill organizer and over time make yourself custom fishtail drills.That's what I thought. Why alter a drill bit if you don't need to. The altering isn't hard, but you have to label the bit and segregate it from your normal bits.
Maybe I got lucky (twice) on that sheet metal box I cut through. Thanks for the idea on modding the bits for plastic drilling. Haven't done much plastic drilling, so I just blunder my way through it. If I need to drill plastic, I will keep this in mind.Protip: Get a standard drill organizer and over time make yourself custom fishtail drills.
We make them like this, with the center just proud of the flutes which lets the center act as a piolet and the flutes cut through grabby materials (plastic, sheet metal, wood etc) without trouble. Make them and put them in an organizer and next time you need this you either have one on hand or have a reason to make another for your arsenal.
Bad paint rendering, but you get the idea.
Their good for much more than plastic.Maybe I got lucky (twice) on that sheet metal box I cut through. Thanks for the idea on modding the bits for plastic drilling. Haven't done much plastic drilling, so I just blunder my way through it. If I need to drill plastic, I will keep this in mind.
