MKSJ, yes the gear is turning. Along with the gearbox input shaft gear. They are all connected so it one turns the other turns. (Sorry, hit the bold button by accident). The position of controls in the picture don't mean much since I have tried various things at various time and moved them all. That was just the last position I had them in for whatever reason. Don't recall what if anything specific I was doing at that point.
Your manual is a lot more informative than the Warco one I downloaded.
The feed selector (H in your manual) does not move into the E or F positions. I suspect that is where the problem lies. But even when it is put into the A or B position nothing happens. IT doesn't feel like a positive detent or I should say it is not consistently a positive detent. I suspect that the bell crank inside is loose on the shaft or something and even if it does go into some semblance of a detent it may not actually be in position. It is hard to figure out how it works from the parts diagram exploded drawings.
Markba, I tried removing the electrical panel but it only goes into a cavity between the headstock and gearbox. The gearbox has some thin metal cover plates to prevent seeing inside. To remove those I have to remove the headstock.
