Valve seals done, cams re-installed and phased:
You can see the cam “jigs” on the rh side of the engine. They’re the black pieces that don’t look like they’re a part of the engine. They hold the cams in the correct postion for installing the timing chain.
What a PITB those seals were! Well, truthfully, the seals themselves were easy. I’m used to working on NA V8’s and such, where the stems, spring keepers etc are a decent size. Those things are TINY on this engine! I’ve seen chips come off the fly cutter bigger than the collets! Was a heck of a time trying to finagle them back into the spring keepers while holding the springs compressed.
This is actually the first time I’ve done valve seals without removing the head. I’m not going to say it was “easy”, but it wasn’t that hard either. Just a lot of fussy little bits. The tool kit I bought to do valve seals with the head still on the engine worked great:
I was actually surprised how well the cylinders held the compressed air I was pumping in to them to hold the valves shut. I’m thinking this little engine would do well on a leak down test, which is a good thing. Tool kit was money well spent, made the job not only easier, it actually made it possible.
Next (tomorrow) is to install the “valvetronic” operating springs, which will be a doodle with the special tool I have for that:
Sure, you can sort of “muscle” them into place with a modified big screwdriver, but having the proper tool is just sooooo much easier. Another money well spent item. Much better than getting one of those springs in the face or chest when your “improvised screwdriver tool” slips…
Then its on to the timing chain replacement.
I’m just taking my time and going at my own pace. Work when I want, sit on my “A” when I don’t.
Wife has her minivan to go back and forth to work, so no rush or urgency to get it done.
There can be times when its nice to have more than one (or two!) driving cars…
