While you are at it, rent a truck big enough to pull it and to stop it. Then round trip fuel at 8 mpg and $5.89 per gallon. You'll also need chains and at least 4 chain binders. If the total weight exceeds a standard drivers license, in Washington state combined can't exceed 26K, most states have limits,t then you'll also need a CDL driver.Could be an issue if it doesn't run. If it runs, just rent a trailer from U Haul, drive it on, and haul it away with your SUV.
The bigger the blob the better the job
