- Dec 26, 2015
- 2,079
I agree with a lot of what’s been said here:
Replace the belt on the 1340 with a Gates Tri-power.
I would stick with Dorian (my choice) or Aloris for the quick change tool post rather than trying to save a few dollars on an off-brand alternative.
Avoid the Dorian “First time buyers kit” that includes the tool post and some tools and tool holders - it looks like a good deal but some of the tools they include are highly specialized and not useful for most people getting started.
That said, I would NOT buy Aloris or Dorian QC tool holders for square shank tools or boring bars. The Dorian BXA size tool holders will take >3/4" shank tools, but do so by lowering the bottom ledge that registers the tool in the holder. To run 5/8" or 1/2" shank tools in the Dorian holders, you have to put a spacer under the tool. The Aloris BXA tool holders will take 1/2" and 5/8" shanks but will not accommodate 3/4“ shanks. In contrast, the BXA holders Matt sells at Precision Matthews, as well as the BXA size tool holders from All Industrial Tool supply ($15 each) or CDCO ($12) will also take a 3/4" shank tool, but accommodates them with different geometry that doesn't require a spacer under 1/2" and 5/8" shank tools.
Before I down-graded to a PM935, I had the Rong Fu 45 square column mill/drill that was similar to the PM833. I got very tired of cranking the head up/down manually, so I recommend you get the Z-axis power feeder option if you can swing it.
Several PM users have complained about blowing capacitors (mill & lathe), or harmonic vibration induced into machined parts from the factory supplied single-phase motors (lathe). If you can see your way to a 3-phase setup, you will have fewer issues. Either run each machine on a VFD which gives variable speed control (mksj is the guy here to help with that) or get a simple phase converter for your two machines.
Lathe chucks depend a lot on what kind of work you’ll do. Matt sells some nice 3- and 4- jaw upgraded chucks. I use an ER40 collet chuck the most often and made my own, but I hear good things about the Shars Set-tru (I no longer allow any Shars in my shop).
