- Oct 31, 2016
- 2,649
I am going to repeat what I said before. Look for the highest quality lathe you can find within your budget. If that lathe requires you to turn between centers. So be it. It will be much easier to learn on and work with a quality lathe than to have to rebuild, modify or do whatever to some piece of junk that you bought just because it has a large spindle bore.
I am not saying that you should only buy old American made lathes. If buying new buy from a reputable company that stands behind their product. If buying used take some DI's and mag bases with you to check for run out. A long straight edge to check for bed wear. Look closely for anything that looks damaged.
When I bought my lathe my budget was way less then yours. I concentrated on estate sales where they were selling off grandpa's junk. I looked for a good year before I found my lathe only a couple of miles from my house. Paid way more than my budget but the lathe had only been used by hobby machinists and came with every accessory in the craftsman catalog except for a taper attachment. Some of the stuff was still new in its original boxes.
As for threading you will be threading towards the headstock. I did a lot of practice on pvc pipe to get the process down. Then practiced on steel. Didn't take long to get the hang of threading.
Be patient. You will find what works for you.
This is just my two centovos.
