B
BRIAN
Forum Guest
Register Today
After looking at the forum I can see that a lot of you have nothing to do, so to save you getting bored I will drag up a question i raised on this forum when the numbers were less than 1000.
The engine in question is a Commer TS3 a 3 cylinder 2 cycle diesel
In the last stages of its development before G M pulled the plug , the makers of the fuel pump CAV
developed a version of their DPA distributor pump for this engine.
Now??? the pump ran at half engine speed Not at engine speed as normal ???
So how was it done???
Thinking caps On, Unless you know!!!!!!
Brian.:nuts:
Brian.:nuts:
