Was this the one that had the injector pump mounted on the top of the engine, and the pump was driven off the back of the crankshaft. ,in separate housing before the transmission bell housing. It was similar to a twin cam design, two or three lower gears driving a chain to two upper idler tension gears, then the final gear on a drive shaft going to the injector pump. It had a sort of shaft plunger setup, that rotated compressing the fuel. God old age is creeping up on me. We had one in the shop I attempted to worked at in New York to work. Technical info was hard to come by, we ended to sending it down the city for a gentleman to work on. He sent back schematics, but it still baffled me.
I spent the last hour looking through old photo albums for the pictures I took while we disassembled. No luck at all, wife ranting.
