Hi all - I joined this forum a couple years ago but didn't have much time to be a "home machinist" while I was working. I retired recently and now I'm getting more time to work with my mill and maybe add a lathe one of these days. For the record, I was a machinist/NC programmer/manufacturing automation specialist for about 40 years so I'm really looking forward to just playing instead of working!
My current help request has to do mostly with the motor for my mill. It is a 240/120 motor wired for 120 and it has worked fine for the times I've used it over the past couple years. Last week I started a project making some game boards for Christmas presents and today I noticed that the dedicated 20 amp outlet the mill is plugged into is tripping the breaker if I also run my shop vac at the same time (just a little guy, not industrial). I also noticed that the case of the motor is getting really hot and I guess I can smell it a little bit (not sure if its an electrical smell or hot grease).
I really don't know much about electrical so I'm a bit hesitant to tear into the motor. Also, I need to make a half dozen or so of these game boards over the next couple weeks so I can get them mailed out in time for Christmas. Can anyone give me some tips on what to look at? Or maybe where I could get a replacement motor - FWIW, I could live with a straight 120V motor which I assume would be cheaper than the 240/120 motor I have.
I also noticed there are several Husky owners out there when I did a search on my problem. If any of you guys have other info on this mill I'd be greatly appreciative. I saw pictures from MikeInOr of his mill and it had what looked like cast metal handwheels for the table. Mine are plastic and all have had the "handle" break out of the wheel - I'd love to know where to get a metallic version. I also saw where Radials was doing a complete rebuild on his mill. He mentioned maybe starting a thread on the rebuild but I haven't found it so far - anyone know if it got created?
That's enough for this post. Thanks in advance for the help!
