- Jun 17, 2011
- 2,062
Phil,
Mine has the BS stamp in the same place. The 153 may mean the yours is put together from several lathes. It may be that earlier tailstocks were stamped on the underside. Mine is on the end, right above the alignment index marks.
I can't tell how the end nut comes off, as it's painted after installation. I would assume right-hand thread, since the heaviest load it will see is with the handwheel being turned clockwise.
I think the only S.N. on the headstock is on the brass plate on the QCGB. They probably marked the tailstock because it is easily and routinely removed. Two or three tailstocks on the shelf in a large shop could lead to mixing them up. Then everyone's work would be tapered. If your lathe was originally an A model, that would explain why there is no plate on the headstock.
