You'll want it set to AP Bridge both ends. That essentially extends the remote end into an extension of the house network, rather than being a segregated joined network that needs extra config to do anything sensible with. Get that up and running and it should "just work"
Yes it does create a separate network. Internet only works over the wifi.The "router" mode is causing you to create what amounts to a separate network on the RadioLabs system. It can work, sort of, but you will end up creating a double-NAT that can cause other issues.
It sounds like the radiolabs setup is just to connect to the main router? It's not to distribute wifi? Try Client Bridge. That should connect to the "main" router over wifi and give you working wired access as if you connected over wifi to the main router. It also avoids having a repeater setup, which cuts throughput in half and can create another failure mode. You can add an AP there to provide wifi, but make sure you disable DHCP on the lan and connect to one of the LAN ports, ignore the WAN port.
Certainly setup (for me) would be easier but as I stated before, trenching is not an option right now.It would be easier to run CAT5/6 and just run a router in the shop. I wish I hadn't gotten lazy after digging my power trench and just laid another run of conduit for a hard line. Instead, I'm using a patch antenna on the house to talk to a wireless bridge inside the shop. That means manually connecting my phone to the bridge instead of seamlessly transitioning to a router, like the rest of my home network. It's great for my shop PC that never leaves the bridge, though.
You can't set the IP address static? That doesn't sound right, should be able to just type in a 192.168.x.x address. If not I would question their support tech.Yes it does create a separate network. Internet only works over the wifi.
If I change to "Client Bridge" I lose the connection to the primary router.
In either "Client Router" or "Client Bridge" and DHCP disabled the LAN address is always 10.x.x.x
Yes, that's what I would do. Your TP-Link router is serving DHCP but apparently it's not getting to the LAN interface of the wireless bridge. Set that to 192.168.0.200 with a subnet mask of 255.255.255.0 and see if you can ping the outside world while hardwired to the LAN interface.So set the RadioLabs LAN to a 192.168.x.x static IP and disable DHCP?
Sent from my SM-G981U using Tapatalk
