- Oct 17, 2018
- 922
I used split plastic tubing on my DRO setup. The tubing came with an "unzipper" that made it easy to get the cables into the cover. It would have been much more difficult without that little thing.
It sort of depends on how long your cables are. A long cable with the spiral tubing could be a pain. It's not the cable itself, it's small enough to slip inside, but the connector on the end that's the problem.
An "unzipper"? I've never heard of that. Is the tubing able to be sealed up with some sort of zipper? Do you have a picture? The split tubing I'm familiar with just has a slit down the length and the wire is stuffed inside. I've seen zip ties used at the ends.
The long cable wasn't really a pain; I just wrapped it around the wires. It only took a few minutes.
