[4]
Angle grinder disc fitted up on bench grinder finished
[3]
[10] Like what you see?
Moper361
Active Member
Sep 15, 2017
223
Likes
367
#1
Has anyone here ever tried to fit a 7 inch angle grinder disc on a bench grinder .I am planning on trying it so as the issue of grinding on the side of a proper bench grinder wheel is not an issue as a angle grinder disc is designed to do this .
As you can see from the pics below I plan to make a spigot with an internal thread and then a shaft this would the threaded spigot would retain the belt sander wheel in place of the nut and then the shaft would be turned down to 22 mm for the disc to go onto ,there would be 2 sandwich washers just like an angle grinder uses to retain the grinder disc .Also the disc would have support from the belt sander wheel as this is same diameter .I think it would make life easier being able to just change a disc rather than reglueing sand paper onto the old disc every time it needs to be replaced like it is now
The grinding disc would be well within its rpm limits 5000 rpm but still usable at 2600 rpm as this is my bench grinder rpm .It would not be for large jobs but just gives and option of grinding on the side of a wheel .i would also use it for sharpening drill bits with my jig . The spigot shaft would look something similar to the rough sketch I attached and from the pictures I think you can see what I plan to do .
Is it a feasible idea ?
Any warnings or advice appreciated
FOMOGO
Sep 2, 2013
1,858
Likes
1,794
#2
Worth a shot I suppose, but angle grinders only use a small portion of the flat part of the disc as they are consumed in normal use, while the outside diameter gets smaller and smaller. The discs are reinforced with fibers to add strength for their designed use. As you would wear down the flat portion of the disc in your application it would gradually degrade it's over all strength, and could violently self destruct. Thinking a cup style wheel might work better for you. Mike
Moper361
Active Member
Sep 15, 2017
223
Likes
367
#3
Yes Mike you would need to be aware of the discs wear limits just like any wheel I guess if grinding on the side and you run down to the reinforcing you would change the disc at a low cost as angle grinder disc are cheap . I do not indent on doing hard work with it basically light work .I don't think a cup wheel would give enough area for my indented use that's why I'm thinking along these lines of disc
Regards Nat
D
Deleted member 120
Guest - Please Register!
#4
Let us know how you get on, I to am fed up with changing the sanding disks
B
Moper361
Active Member
Sep 15, 2017
223
Likes
367
#5
B
That is my main reason trying this out as changing those sanding discs out is not fun and usually needs doing at the most inconvenient time . I think once you run a piece of carbon steel across the disc a couple of times it would reduce the initial roughness of a grinding disc of and should be smooth enough for sharpening drills and general grinding .I plan to machine up an spigot tomorrow I'll post here how it works out
Tony Wells
Platinum
Jan 22, 2011
7,052
Likes
2,135
#6
You probably will end up dressing it flat if you intend to do any tool sharpening that has straight edges.
Moper361
Active Member
Sep 15, 2017
223
Likes
367
#7
Possibly Tony ,It's not a lot of work to experiment a bit and see .It would just make life easier in the long run and I've not got a lot of outlay $1.50 for a disc and a bit of stock which I have already it's only a bit of my time and you never know till you try it .It may well do what I'm hoping for
Tony Wells
Platinum
Jan 22, 2011
7,052
Likes
2,135
#8
It might at that. One more element of concern possibly, and that is the lack of very fine grinder discs if you needed them. Although........for a price I know they do make smallish diamond/borazon type disks for concrete floor polishing. Of course, large areas are done with something like 20" disks, but there are smaller machines to accompany them to work in small spaces and in corners that the bigger machines simply can't get into. They mount to a handheld machine about the size of a router. I picked up a couple of discards from a job a few years ago planning on doing something with them someday. Not sure how much life there is in them, but they are very fine.
Moper361
Active Member
Sep 15, 2017
223
Likes
367
#9
Today I finished my adaptor to fit a seven inch grinder disc on my bench grinder .Its all fitted up and a little messing around to true up run out on the disc and I ran some carbon steel across the disc followed by some tool steel this was to take the very coarseness of a new disc away this smoothed it of a little .i then fitted my drill sharpening jig back up as this is what I originally planned to fit the disc for to eliminate grinding on the side of a stone wheel and also to not have to change emery pads that used to be on the side of the belt attachment .there is no viabration and the disc is running well bellow max rpm limit so feel safe with it all .It seems to grind the drill bits better than the emery and less heat is produced ,The finish is ok and sharpens bits no problems and no apparent were on the disc . image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg
D
Deleted member 34477
#10
I'd call that successful.
Nice job!
Moper361
Active Member
Sep 15, 2017
223
Likes
367
#11
Hi Tony just for your interest i tried some hercus lathe tool steel on the angle grinder disc attached to my belt sander project .well i am very supprised it tears tool steel away in no time flat with not a lot of heat .It does not leave a mirror finish however fine for what im doing .there is basically now wear to the disc either .here is a pic or 2 of a peice of tool steel i roughed out from just a straight end its not a miror finish but ok for what im doing it took about 3 minutes to rough out and not a lot of heat was produced i was holding tbe tool steel by hand
Moper361
Active Member
Sep 15, 2017
223
Likes
367
#12
B
Brian its all good best thing ive done in a long time carves hss up no time flat and shapens drills bits etc no problem
D
Deleted member 120
#13
Another one to add to the list.
Thanks for posting.
Brian.
FOMOGO
Sep 2, 2013
1,858
Likes
1,794
#14
Nice. Just goes to show, you don' know until you give it a shot. I had my doubts, but it appears to do a great job and the lack of heat build up is a definite plus. What grit disc did you use? Might be interesting to try a finer one, and if the finish improves maybe have a second one set up on another motor for final dressing, or just tune with a stone. Cheers, Mike
Moper361
Active Member
Sep 15, 2017
223
Likes
367
#15
Thanks for posting.
Brian.
Haha Mike its just an off the shelf regular 7 inch grinder disc it feels quite course to touch but seems fine when grinding with it .I will keep my eyes on the look out for finer grit if available if notavailable im happy with it as is im sure if you hunted arou d you could maybe get finer grit
Regards Nat
FOMOGO
Sep 2, 2013
1,858
Likes
1,794
#16
I have quite a few different grits for my 4" grinders. Have always just had coarse for the 9", as it's used for quick removal on heavier material. Your finish seems fine, but you know how it is, always chasing unicorns. Mike
Tony Wells
Platinum
Jan 22, 2011
7,052
Likes
2,135
#17
Looks like a success to me. I imagine the main reason it stays as cool as it does is that the grit is fairly coarse. This is fine for rapid stock removal, but I would think a little stone work on the edge would eliminate any issues that might arise from that. If you get a finer wheel, you may start to get some heat buildup.
rock_breaker
H-M Platinum Supporter ($50)
Dec 31, 2010
552
Likes
265
#18
Glad your project is working. Not sure how to say this but I hope you are considering guards around the disk. My personal experience with a side grinder has been no mishaps. Thanks for sharing your work and hope it continues to serve you well.
Have a good day
Ray
B
British Steel
#19
Cool idea, next step add one of the EvilBay diamond-impregnated 4" discs in the middle for finer finishes? I just clamped one under the washer against the wheel on a little 6" grinder for sharpening tungstens*, it works much better than I expected!
Dave H. (the other one)
* My EvilBay purchase for the month, I've wanted a TIG welder for Some Years, it came up "untested, spares-or-repair" stupidly cheaply because it's 3-phase and should do what I want (much more than I need, it's quite posh!) after a bit of investigation and repair if it needs it (I used to be an electronics tech', on weird and wonderful equipment...). I have a phase converter that can feed it as long as I stay below about 200 - 250 A and I want to work on thin tubes, it might just work!
Silverbullet
Gold
May 4, 2015
3,420
Likes
1,673
#20
If you turn your belt to vertical it will do a better job on sharpening drill bits. Big plus it's easier to thin the web then on grinding wheels. With different belts it's a super drill sharpener. Grinder discs wear very quickly I think you'll find bits getting longer on one side not much but it will show up the more you sharpen. Just my thoughts and yes I use the same sharpener on a 1"x42" belt grinder. And I got paid to sharpen hundreds of them . More for thinned webbed drill bits.
Silverbullet
Gold
May 4, 2015
3,420
Likes
1,673
#21
Done it again , DPost
[6]
[5] [7]
