- Feb 25, 2021
- 3,130
Just a little side project that worked out nicely. I made up a holder for the typical 3/4" weldon shank annular cutters to work on my lathe. A male morse taper 3, with a 3/4" hole and set screw on the end.
My lathe tailstock and my toolpost drill chuck mount are MT3, so I can use this to throw annular cutters in the lathe. The cutter illustrated above is 1.125 diameter by 2" maximum depth. Ideally I would have milled a tang on the end, but that got truncated when I realized my compound only had 3" of travel and the MT3 is spec'd 3.19" long with tang. I just left the tang off, although it would have been possible to work around that and make the taper longer by stepping over with the carriage and making the tang taper a few thou less. I may yet make another one fixing that.
Works pretty well. I was originally going to drill then bore this, but snapped a drill bit off on the initial 1/4" pilot hole, so this was my way of getting around the piece of embedded drill bit. I still need to bore it out to finish dimensions.
Sure, would have been faster to just throw away the part and start again, but what's wrong with spending a few bucks and a few days (shipping on the cutter) to save a $15 slug of steel?
